ROCKETCINE-X Bugs, Comments, Help...
Status
Not open for further replies.
Hi Deanan, and thanks for your reply. Can you give a rough estimate for the availability of the Windows version?
Everything that's in Rocketcine is going into REDcineX so the windows version will be through REDcineX.
Hmm... that includes Rocket support as well, I suppose?
Thanks Deanan. Why are you still up at this hour, man? ;)
Hi,
I am having problems with processing to Avid DNX36 8 bit MXF files. I am testing with a batch of clips that export fine using the Quicktime method, so Im pretty sure the files themselves are ok.
Most of the time the application will quit out to the desktop without an error message (after processing several files correctly). Occasionally it will just stop processing at a certain point with the "Exporter unable to assign frame to decode" error that Olivia mentioned a few threads up.
Deanan, is this a problem you have seen before?
Hi,
Can you email me the log files?
This is a report for the latest build. It seems it has the tendency to crash when I select more than one reel to render.
can you explain?
Also, always email me the crash report and the logs if you have a bug report.
Load up multiple footage from multiple folders (say you have multiple RDM folders with RDCs) then try to render will lead to occasional crash.
Also, the new build seems to have problem updating the adjustment you make on "Shadows" through SDI output.
The latter is being fixed.
Can you email me the crash report and logs for the multiple folder thing?
We'll try to recreate.
I'll do that next time I run into the same issue.
by the way, I really like the shadow control a lot. I was doing the similar adjustment using master gamma and the curve on Apple Color, but the FLUT and shadow provides the same or better to preserve the relations on the highs without blown and the dark area to be rich in gradation.
Kudo's to Deanan for fixing the HDSDI output with shadow control on the new build!
Hey Deanan, any update on Breakout Box supporting HDMI , etc?
I know you got a ton on your plate, just curious as I cant really utilize the box for my Panny 12 because I dont have an HD-SDI Board... Hence the B/O Box :)
thanks man!
thanks man!
Bump, not sure where else to ask the above, thanks Deanan!
Email me the crash report and log files please.
(everyone should know this by now... :)
sorry deanan, was in a rush and the computer the crash happened on went out the door the second it was done with the job. had no time to get log file to you......apologies.
Status
