RED DOT on Footage - HELP!!!
Christopher Lansell
Melbourne
www.redcamerahire.com.au
Hi Everyone
Over the lasy two days I have been shooting for a surfing film using a 250mm with a doubler and I keep getting a larger red dot in the middle of my footage? Does anyone know what would be causing this?:emote_head_explode:
A001_C017_02048V_00241.tiff
It is a 1k tiff so it might take a sec to load! I think somehow the light is reflecting off the sensor back into the lens and then back onto the sensor?
Are you using a IR Hot Mirror filter of any kind?
Have you visually inspected the lens? Try another lens to see if it persists. Other than that I'd make sure about a black shade calibration.
Have seen this before with wider (18, 25, 35) superspeeds used with rosco ir cut filter & nd's shooting into bright backlight. Suspected it was light reflecting off of the ir sensor back out through the lens. Was able to duplicate behavior on all 3 cameras on set.
Hi Christopher,
I'm thinking flare. Looks like you are shooting into the sun as the subject is backlit. Do you have any grabs where you have shot away from the sun?
From the description, it's flare. You may need to switch out to a zoom covering the 500mm range as it sounds like the extra glass in the doubler + 250mm is causing lots of reflection.
I had this problem with one lens out of a prime set. We were trying to figure out if it was flare or reflection of the sensor or what. It had a red/purple hue. Ultimately the only solution was to use a different lens.
