David (dudi) Namir
Does anyone have an idea if the Epic and Scarlet will have an adjustable lens mount for back focus adjustment or with shims?
Will any external accessory be needed for doing that?The mounts don't have to be shimmed or adjusted the sensor itself is adjustable for back focus.
Will the camera themselves be with that capability?
These are important details that Red don't inform. Either they still don't know, don't want to be committed or simply don't think they are important.I believe that Jarred said that it would be adjustable via a screw. I could be recalling it totally wrong, but if so then one would be device such as the NULL Lens on to set the backfocus.
Jim Jannard confirmed to me personally that the future RED cameras would work with the NULL Lens system with no issues. We designed this family of products to make sure that they performed well for you for a very long time.
Don't forget- when you get the Optimator you'll have additional advantages:
1. Number to define max resolution
2. Chip centering reference
3. full chip coverage with hi res corner targets
4. Neutral munting system for use with Canon, Nikon, PL, Panavision mounts on camera.
5. Number of important upgrades to do color balance, single channel noise verify, MTF software and more coming to NAB.
The Optimator supposed to be the best long term collimating system.
Says who? You?
For the record, I agree with you 100%That will be my choice.
You pay a bit more but you get features you would need now and any time in a future something like it was already mentioned above:
3. Full chip coverage with hi res corner targets
5. Number of important upgrades to do color balance, single channel noise verify, MTF software...
Pretty good and attractive instrument...isn't it?
The Optimator has a built in reticle and a light source - It will work quickly and easily anywhere. You can check FFD in seconds. It also has guides that will allow precise centering and alignment.
Matt Uhry
www.mattuhry.com
