Emergency Rental Request due to onset Camera Failure
kyle hartman
39
Hollywood
We are currently shooting on the RED ONE in Tarzana, Ca. Halfway through the shoot we ran into a technical problem with the camera. The image has a green interference/interlace-looking glitch in the middle of the frame that won't go away. I will post an image soon showing the problem.
If anyone knows how to fix it or where we can rent a RED ONE body for tomorrow and the day after let me know ASAP!
Here is a frame grab showing the image malfunction.
CF Module not working now as well, Cannot install build 21 here on set.
Did blackshading, default system setting and checked all the cables etc...
Def not a overheating issue.. Wondering if the CF module is related to this imaging malfunction.
AFAIK you can do firmware installation using the built-in SD card reader.
Did you try to record on a Red Raid or Red Ram ? I had a similar problem about a year ago and it was the CF Module.
I would try doing a black shade calibration again. We had a similar issue, by doing the black shade it went back to normal.
Colin
