Adam Sherman
- Jan 29, 2010
First RED Edit I've done. Stumbeling my way thru, watched a ton of vids and read walkthru's on avid's site but have one question that's killing me. For some reason when I select all Transcodes(ctrl+shift+a) in Metafuze, they select, but when I try to change a field (format,resolution,burn-in, etc), the change is only applied to one of the clips instead of all. Right now dealing with 250+ clips. Did painstaking way to let them go overnight, but getting another 500+ clips tomorrow... really don't feel like tweaking that many settings on that many clips. Used detail panel and tried about everything the video walkthru's (Avid Screencast #8 & MidwestMediaGroup's on Vimeo) showed me to no avail. Basically it looks like I do exactly the same thing they do but with different result. Uninstalled and re-installed about 3 times before I bit the bullet and went ahead manually just to get em going. Editing on Avid MC, Vista-Biz Machine, Metafuze V2.1. Transcoding for offline edit, R3D 2K images down to mxf 1080 23.976p, DNxHD 36, Eight Good res with Low Debayer and default Key Number & TimeCode Burn-In. Any help would be greatly appreciated, thanks in advance.
