Shutter Angle Mode and Over-cranked Frame rate in Metadata?
Brandon Kraemer
53
Is there any way to tell what the shutter angle mode (syncro vs. normal) was set to on a shot from the metadata, and if so how would I find this information? I can see the shutter angle (100 deg) in Redcine.
Also... is there anywhere I can see the over-cranked frame rate in the metadata? All I can find is the time base (23.98).
Build 20.1.6
Thanks in advance.
bk
Bump...
Still looking for the above metadata from a shot. What about the shutter speed? I can see angle, but not over-cranked frame rate, so I can't after the fact calculate the angle or speed. Or can I?
Thanks in advance.
bk
Hi Brandon,
That information is currently not in the metadata
