adobe primiere pro cs 4 "this project contained a sequence that could not be opened. no sequence preview preset file or codec could be associated with this sequence type." format r3d 2k
I dont use premier so i can't help you , but i can tell you that this forum is a Real Name forum so send them your real name before they ban you... which version are you using ?
