Rob Ruffo
I totally agree, I know well the benefit of resolution downsampling for acutance. As a photographer, I practice downsampling all the time.
But I have the impression that the noise level and type play a part in what is better to do. Perhaps is noise is an atomized tempest, a little downsampling may just cut the trouble away, and than it may even be worthwhile to up-res again. Or a good noise reduction may solve it.
Anyway this is still not the case witha a super clean image, where there is no noise.
Some say that 4k with bayer is not real 4k. I partially agree, since technically it's not.
But, if the image is clean, it's so easy to make bayer 4k look as sharp as downsampled 4k or monocrome-type 4k cameras, that I'm pretty comfortable at calling it 4k.
Of corse I think the same for 3k.
That said, I think a clean 3k can be up-ressed to 4k succesfully - well at least in photoshop; I don't know what it will be like with Red Scarlet and Red One.
If there is no noise to be increased, it will not increase.
I think a given acuity, which is ALWAYS related to it's optimized image size - that's why when I up-res, the RELATED acuity decrease (the new image has less acuity), is less and and less important as the original resolution was high.
I can distinguish a person from another in a group of ten or one hundred (low resolution)
I will never be able to distinguish a person looking at a square full with a million people (high resolution).
I certainly agree with most of your theory as well as with most established theory,
but not to your conclusion:
I think for a prject that was shot 90% at 4k and 10% at 3k, I'd prefer to stay with 4k and up-ress only that little bit.
It's not like up-ressing a 10% from, say, 1 megapixel to 1,3 megapixel: even if the jump is proportionally the same, at this low spatial frequency it is much easier to notice a difference in resolution or acuity - we may just consider acuity as ratio between resolution and image size.
Also, a more trivial reason could be uniformity in the worklow and the process.
Usually, Super 16mm features were, and still are, blown up to 35 for theatrical release.
The importance of acuity, especially if not bounded to resolution, has a lot of limits, otherwise all movies shot on 35mm would be reduced to Super 16mm to gain some acuity. There is always a point where, running behind acuity, we start to loose real bits of information. That's why to me resolution is more important than acuity. You can alsways make the resolution more visible with some tricks which enphasize acuity, but you cannot gain real bits of information from acuity alone.
Yes, in a certain way I let resolution seduce me, spoil me, because if I have enough abundance of data for my eyes to be mega happy, I can do whatever I want.
To me, 3k is minimum for theatrical release, and I mean 3k videoprojection.
I can see the pixel matrix of 2k if I watch from front sits. When I saw Blade Runner remastered in high definition this happened.
But the world will skip 3k projection and will go for 4k, and this can't be bad at all.
For similar reason, I may not be able to see beyond 3k even from the front sits.
If that's the case, uprezzed 3k to 4k will be absolutely the same as native 4k for my eyes. Of course, if there was no noise is the 3k, otherwise - you're right - noise will increase.
I think it's a lot about quantity, or to be more precise, we are at a point where, quantity not only can make contingent problems dissolve in the mass, but quality now really sort of depends on quantity, is triggered by quantity.
Every time a make an enlargement of a picture, if the original file was at very high resolution and was not degraded, I can afford not to care about resolution, no matter what size I will print it at. If resolution is high, it is high.
if it was alredy fine for 2 meters high, should I enlarge a print to skyscraper size, resolution would be fine too.
If resolution was poor for an medium size print, I will be poor for everything exept for the smallersizes. Hey, acuity is highest there: but this doesn't mean they are the richest. Quite the opposite. They are poorer than the original file, because they even cut away part of the already low resolution.
If acutance is less than 100%, it doesn't matter at all, since what is perceived as rich image, richer than what we can see, it doesn't have to be optimized.
I mean: it would be worse if a size reduction cut away sothing, and anything above 100% acuity is just lost data.
Thankfully, we are past the point where big screen projection was a problem and acuity would play a dominant role, being impossibly to go over 100% as there was no high resolution to reduce.
I'm not sure hwo you are using 'acuity' here? Please define... A few people have eagle-eyes. I can sometimes see grain in daylight-shot Imax filsm (REAL IMAX, liek what you see in science centers). But... Most people cannot resolve more detail than 1080p watched at a comfortable (read-non-nauseating) distance from teh screen. It is a matter of the resolution of your eyes. This 1080p-safe distance account for roughly 65% - 70% of the seats in any cinema.
A larger or smaller screen makes no differences (unless you are near or far sighted, and not wearing your glasses) as you will (within reason) sit closer to a smaller screen. It's not size, it's fill-factor of yoru eyes' "pixels".
Of course, a family watching an SD Television cannot all sit with their heads right in front of what used to be an average screen size (20 inches) If all screens were still 20 inches, we would not really need HD. There are also limits in other ways, like your eyes have trouble operating in macro-mode, so a 1 inch photo would be hard to look at in proper focus.... But....
Watching video 2 feet away from a "24 monitor, and 12 feet away from a 100 inch screen, and so on - these lead to identical resolutions being resolved by your eyes, and the max that most people can resolve is around 1080p. That said, 4 K DOES downsample to 1080p/2K better, (much better) and it stands to reason that 5K 10K any K would do so even better. But this is not the neatest thing about it. The neatest thing is the ability to re-frame in post. Once you start realizing the creative latitude post-created reframes allow, you get very, very excited about them.
