Steve Wake
I think a lot of potential Scarlet Fixed users have nothing more than 1080p output in mind (and in a lot of cases the final product may only be SD DVD's). A lot of us probably would like to not have to add a lot of hardware, too.
So, after rolling around some specs and features and unknowns (like #21) in my head, I've come up with a list of possibilities for 1080p output that I'd like the RED team to consider. The items I've been musing about include: raw output; 3K has about 2.5 times as many pixels as 1080p; lookaround; 3 gyros that tag each frame with their data; software designed by the camera manufacturer.
Combine these in different ways and I think it's realistic to ask for:
When considering the possibilities of opening up an entirely new customer base of lower-end filmmakers, including prosumers, I think these suggestions would make the Scarlet fixed a lot more appealing.
- Software-based steadicam. Take the gyro info and use it to stabilize the path the camera took during its handheld move. Allow the editor to adjust the path. Greater flexibility in adjusting the path if cropping/downrezzing to 1080p. Could also record the lookaround area and keep the original framing to maintain 3K. (This is separate from any in-camera image stabilization that I hope is the missing feature #21, but if the two were combined there might be an incredible synergy).
- Wide angle enhancement. Record the lookaround area, downrez to 3K in-camera. Probably would restrict the framerate to allow for the additional processing, but shouldn't be a problem in most cases.
- Simulated Zoom enhancement in Post. Software based, but could give superior results compared to Motion-generated Frames given we're starting with raw files.
- Noise reduction through downrezzing to 1080p in post. Again, take advantage of raw processing. I would love to get downrezzed 1080p iso 1600 footage that was as clean as 3k shot at native iso (320?).
