hi everyone
i heard that the Arri Lens Control System can work on the Red cam but it needs a converter to change the power output to RS ...
anyone knows more details
thank you
hi david
i am attaching 4 photos
1.jpg and 1a.jpg is for the red cam
2.jpg and 2a.jpg is for the arri
i want a converter that fits to 1 and 1a (aux 12v) from one side and 2 and 2b (RS) from the other side
thank you
You're going to need a 24V power source for any accessories that draw power via an RS port. Since the RED has no 24V outputs, you will need a 24V source like a brick battery, belt, or power supply.
