Peter Osinski
OK,
So FCP was the first Pro app I learned, but when I got my computer and was planning the post production for a surf film I was working on last year and the year before, I decided to get CS4 production premium because it had all the tools I needed and they all worked together so well.
That was with DV, and now that Adobe has native support for R3D files I plan on staying with it.
I have developed a workflow for editing scarlet 2/3" footage and I would like to know what some of the adobe/red users think.
1. Transfer footage from recording media to Raid
2. Rename original r3d files to more useable clip names (or if this is a bad idea, update metadata for clips so that I can use it to identify clips the way the renaming would have)
3. Import footage into Premeire Pro for edit on 3k timeline
4. Complete edit and basic color correction using source settings on Premiere Pro,
5. send necessary segments to AE for FX work via "replace with after effects composition" tool in Premeire Pro. Use AI and PS to make titles and raw material for effects
6. Edit Soundtack, Dialogue, and Effects using adobe soundbooth as needed
7. Combine all sequences into a master sequence in Premiere Pro
8. Highlight that whole thing and select "replace with after effects composition
9. Do color grading of entire project in AE
10. Save the composition so that the combined master edit sequence in Premiere reflects the color grading
11. Export at 2k (DCI), 1080p (Blu Ray) and whatever other formats I need from Premiere Pro
The reason I want to go back to Premiere Pro at the end is that I heard that AE has problems using more than one processor for rendering certain effects and the same effects get rendered using all cores through premiere pro and media encoder and the whole process is much faster that way.
For a start to finish post production workflow this seems pretty straight forward. Are there any obvious problems with this I don't see? I know AE isn't great for grading, but it's a powerful tool and will fit my minimum grading needs. I won't be doing much anyway because I mostly do sports filming and documentaries.
I have a 2008 model mac pro with 2x2.8ghz quad core processors. I will have 10-18GB or RAM, possibly more, and while right now I am using a nvidia 8800 GT graphics card for my 2 monitors, I plan on getting a 2nd Card for use with a 3rd monitor which will be for previews and color correction.
I am still working out exactly which raid I will be using and how that will be set up.
