Andrew Rieger
Alright, I figure that the lens thread would be the best place to ask these questions. Here it goes...
So I have decided to purchase a Scarlet 2/3" and I am looking into the lens options available to me. There are the Red miniprimes but I am still waiting to see the optical performance and and the possibility of using a standard follow focus so for now, they are out.
Second, where I live, Super 16 glass is pretty hard to come by with limited choices and from what i hear, may not resolve the 3K sensors.
Super 35 lenses are much more abundant and have a greater selection. The problem is, I am finding the discussion on field of view, crop factor and depth of field changes when using Super 35 lenses on a a 2/3" sensor, to be very, very , very confusing.
Yes, I have heard the phrase, "a 50 is a 50 is a 50"
For this example I will be using a six lens set of Zeiss-Arri Ultra Primes (16, 24, 32, 50, 85 and 135mm to be precise)
I know that a Super 16 50mm lens will have the same fov as a Super 35 50mm lens but things get interesting when you place the S35 lens on the S16 cam.
According to other posts, the crop factor of S35 cine lenses on the 2/3" sensor is 2.47. Thus, when using a S35 lens on a 2/3" chip:
S35 16mm= 2/3" 39mm
S35 24mm= 2/3" 59mm
S35 32mm= 2/3" 79mm
S35 50mm= 2/3" 123mm
S35 85mm= 2/3" 209mm
S35 135mm=2/3" 333mm
I am not saying that the lens turns into another lens (everyone gets upset and corrects you when you say that a 50mm S35 lens turns into a 123mm lens), I am just saying that the field of view changes.
Lets just say that I am using the 85mm lens on a RED One, I then switch to the Scarlet 2/3" from the same distance to the subject. I want the same field of view that the RED One had so I then put the 32mm Super 35 lens on the Scarlet, resulting in a 79mm fov which is not the same but very close. Is this the correct way to do things?
Finally, despite the "a 50 is a 50 is a 50 thing", isn't it true that in the example above, the 32mm S35 lens will have a shallower depth of field than say, an 85mm Super 16 lens at the same t stop? I seem to recall that crop factor also changes the DOF characteristics of lenses, similar to how many people make the depth of field more shallow on prosumer small chip cams by backing way up and then zooming way in.
If my understanding is correct, then when using a 2/3" chip, a Super35 32mm T 1.3 will produce a more shallow DOF than a Super16 85mm T 1.3 lens, despite the fact that the field of view is very similar.
Wow, that was a mouthful. I'm just a beginner trying to gain understanding. You have to start somewhere.
S35 16mm= 2/3" 39mm
S35 24mm= 2/3" 59mm
S35 32mm= 2/3" 79mm
