Scott Dominick
- Jan 16, 2009
I'm trying to use Monkey Extract to conform a cut via an XML and I'm having issues conforming the results of Monkey Extract.
When in monkey extract I've set the create ALE option which creates an ALE for each clip. I'm also trying to use the new XML that is generated as well. I've read the Red step by step manual and honestly I find it quite confusing. I'm not clear on how to get my XML back into Avid and how to relink everything properly. What am I missing? The generated ALEs are of no help at this point. Also should I be decomposing my sequence and making my XML scan list from that? or is a cut list generated from my duplicated original ok?
Finally, what is the closest codec available in Monkey Extract that is close to the NONE codec. My editor likes to import uncompressed media back into the Avid when conforming.
Thanks,
Scotty D
Thanks,
Scotty D
