Problem Sending Proxies to Compressor
Julio Quintana
Austin, TX
www.juliomquintana.com
Hey guys. I have several hours of interview footage. I shot in 3K, dragged the _M proxies into Final Cut, and used Video Filter to add timecode burn-in to the footage. I choose clips out of the timeline and send to Compressor to make mpeg-2 for DVD. Some clips have worked fine. The two longest clips keep failing. They are around an hour long. I tried exporting pieces at a time, but no luck yet. Any ideas?
Thanks,
Julio
i'd use redrushes...i'm not sure why anyone uses proxies with compressor anymore. If you're just going to mpeg-2 anyway, you can make fast transcodes...i'd transcode the longer files, because the spanned clips are undoubtedly the culprit.
come to think of it, i encountered that same problem a long time ago- balky spanned clips in a proxy timeline - and solved it by transcoding, though the tools for that are much better than they were when red first came out...
