Size of optimo 12:1 due to lens breathing?
Andrae Palmer
52
Fort Lauderdale, FL
www.facetmedia.com
Is the design of the Optimo 24-290mm so large due to minimizing lens breathing? I read somewhere that large lens elements help to prevent lens breathing. I'm interested in the Angenieux line and would like to know as much as possible.
The size is mostly determined by max aperture at the longest focal length for a defined image circle. T2.4 is very fast for a 290mm lens. I'm sure other things impact size too.
Ok what about the weight? Why is a 25-250mm T3.9 (original) around 5 pounds and the 24-290 T2.8 is almost 25 pounds?
optimo performance
optimo performance
Word of warning: If you see both lenses projected you will never want to use the old 10:1 again. It's that bad compared to the 12:1
I suggest don't even try.
10x to 12x comparison
This is a comparison. Although as of late I'm a bit reluctant to post comparisons for fear of death threats. Anyway it is a test I did where I just tried to eliminate as many variables as possible. Both images are shot at f4, 10', 250mm. Please take with a grain of salt. The image on the left is the 12x.
Best, Peter.
I agree with Jacek, the old 10:1 isn't even close to the same league as the newer 12X. The large size is due to several factors. One being the T-stop of 2.8 on that massive cannon. Which at T2.8 the actual aperture is probably a good bit larger than F2.8 because there's no way they're getting 100% light transmission through that beast.. Th larger elements also gain more light-gathering ability. Also the floating elements and breathing compensation. Larger elements don't really minimize breathing, it's what the lenses do with their elements. I'm not a lens tech, nor am I familiar with the internals of the Optimo 12X, so I can't really explain all that's in there.
Good comparison, Peter. I understand your fear of posting comparisons...
The Optimo is very sharp wide open, the same can not be said of the old 25 - 250 which breathes & flares rather easily.
Yeah the old 10:1 (T3.9) is pretty bad on far focal lengths. I just like its organic look. Would love to get a HP or HR. The old T3.9 was the first lens I tested the RED with last year... fell in love with it. I like pretty much any lens from Angenieux. Slowly will work my way up to acquiring a modern one. I'll have to read up on what the focal lengths and aperture have to do with size... still can't comprehend it.
The 24-290 is like having an entire set of primes in one lens. It is as close as you can get to shooting with primes in a zoom (except that its T2.8 vs faster primes). We have shot entire spots w/ only the 12:1. It matches very well with our Ultra Primes too. Love this lens!
Me too... I can only drool at it from a far or rent it.
