FS: Sennheiser MKH 415T
Yoji San
Brooklyn, NY
SOLD
100% working Sennheiser MKH 415T
The classic Hollywood sound...
Those microphone were build to last and will survive anything. For example, if you had to record sound in a humid environment, If you are shooting in a high RF place like New York City, don't look any further this is your MIC to go!
It is internally exactly the same as the Sennheiser MKH416T and is powered by 12V (not phantom power)
I am asking $500 (+Shipping)
Here are the specs:
Transducer: Pressure Gradient/Interference Receiver Condenser
Polar Pattern: Supercardioid/Lobar
Frequency Response: 40 Hz - 20 kHz
Dynamic Range (Typical): 117 dB
Signal-to-Noise Ratio: 81 dB
Maximum Input Sound Level: 130 dB, (@ 1 kHz)
Power Requirements: T-Power 12v, (± 12v)
Output Impedance
Nominal Impedance: 25 Ohms
Minimum Terminating Impedance: 800 Ohms
Output Connectors: Tuchel Type
Pad : None
Low Frequency Roll-Off : None
Applications: Film, Radio and Television, Especially for Outside Broadcast Applications.
Dimensions: 9.84 x .74 (250 x 19mm) LxD
Weight: 5.82 oz. (175 g)
I own a number of 415s as well as 416s and think they're practically interchangeable. As mentioned the only difference is phantom resp. T-power. They both, for all practical purposes, sound the same. They both work in any kind of weather, dry or humid. They are 'classics' for a (good) reason.
