Stefan Scherperel
For the last few months i have been using the following workflow.
Premiere 4K timeline
Cut Project in Premiere
Impot Premiere footage into AE - Not dynamic link so i can have access to individual clips
Color correct, composite, effects.
Render 1080P at full or half depending on project and footage used
Use multi-core rendering when available, not always.
Have a 3 - 8 hour render for 3-4 minute projects (8 hours for full - no multicore becasue of certain effects.)
Now even though I have a fairly new Core i7, overclocked, 12GB of ram, I have always had problems with multi core rendering, usually having to use only 2 processors of 4 becasue it eats too much RAM. And some effects don't allow multi processing (Yay 8 hour render)
Today I was just sick of it and decided to try somethin new. I found that if I set my Premiere timeline to my output size (1080P) not only could I get much better realtime performance, but when I render from premiere with Adobe media encoder I use all 4 processors, 8 cores EVERY SINGLE TIME!
I just rendered out a clip from premiere using all the same color correction that I did in AE for the same clip, including some effects that don't allow multi processing and guess what, at 1080P It renderd the clip 6 times as fast.
If Adobe media encoder can use RAM so effeciently as to use all of my cores all of the time, and with effects that AE says can't use multi core rendering, then what has the AE team been doing. I have nothing but headaches trying to render from AE, and with Premiere the end result looks exactly the same.
Hmmm, I think I have a new workflow emerging.
