Hello all
This is my first posting so forgive me if I'm asking the obvious and its also in the right place.
I have just finished an edit for a friend on Final Cut pro, who shot it on a red camera.
I have a little bit of experience with FCP and Red but I'm no expert.
The footage i had to work with had been trans-coded from the 2K RD3 files by someone else to Apple pro res and they looked good.
The project all worked fine until I came to outputting it for the grade.
The graders had asked me to send them a Tiff sequence so i reconnected the footage back to the F Red proxies so i could create it, I had done this a couple of times before and it worked fine.
I noticed that the proxy files looked like they had a blue tinge to them.I had not seen this before in the couple of times i had reconnected on other projects.
I now know that I should of called the graders at this point to see if this was right.
When the people doing the grade saw them they starting talking about "debayering" and had problems getting the Tiff into there system, I don't know what they are using to grade.
I have looked online at this and frankly am left a bit confused.
In the end they asked me to make an EDL of the cut and they made a DPX file and graded from that.
I would like to know more about this to avoid this problem in the future.
If this all makes sense or i have not put enough information then i will add.
Any help advice or knowledge on this would be fantastic and much appreciated.
Simon
Simon
