Red Rocket, will it do the job?
ThomtheEditor
Banned
Los Angeles, CA
I know the red rocket will give us unparelled transcoding speed which is great; the other thing i'm looking to do with it is real time output to dvd recorder w/ timecode burn-in for real-time dailies creation; is this a functionality that is available now. I know it was in the works as of a couple weeks ago; but we're starting to shoot monday; i held off on this decision as long as we could.
thanks,
~T
Guess you need a DVD recorder with component or sdi input. If they exist.
They do exist with firewire but then you get DV quality.
I know the RED Rocket™ will give us unparelled transcoding speed which is great; the other thing i'm looking to do with it is real time output to dvd recorder w/ timecode burn-in for real-time dailies creation; is this a functionality that is available now. I know it was in the works as of a couple weeks ago; but we're starting to shoot monday; i held off on this decision as long as we could.
thanks,
~T
There is currently no way to do tcb with Red Rocket, you would need to use Red Rushes, which also does not support Red Rocket. You can run HD-SDI from the RR through a HD-SDI to HDMI which many consumer DVD recorders support. There are HD-SDI to SD component or composite convertors out there that work as well.
  • Thread starter
  • Banned
  • #4
I was under the impression that you could (or will be able to at some point) add a tcb in rocket-cine; run that out the sdi port thru a downres to sd component into dvd recorder, is there any rough eta on when the next build will be released?
~T
~T
Cuurently both tcb and audio do not flow through the HD-SDI port of the Red Rocket.
