Alex Mack
Like?
How tiny it is. My dream sensor would be like an inch or so.
2/3s is pretty small. But workable in a way 1/3 is not.
There is enough space for four 1/3 sensors in a 2/3...
Like?
Hey halsu, why don't you give an in depth explanation of focal length and depth of field.
Truth is, you're really good with that... (hv20.com)
What kind of DOF is the human eye closest to?
DOF is all to do with the sensor size, focal length of your lens, and the aperture you are using.
That's incorrect. DOF does not depend on the sensor size. It does, however, depend on the CoC (Circle of Confusion).
27 Degrees FoV
s35- 50mm/2 = 25mm
65mm- 100mm/2 = 50mm
2/3” – 20mm/2 = 10mm
Sensor size - Focal length/F-stop = Aperture size
Suppose an image in photographed on 35mm film and show in a large theatre, and we assume our audience is one-third of the way back from the screen and we know that the eye’s maximum resolving power is usually considered to be one minute of arc. We can now work out the size of the smallest dot on the screen that the eye can see in perfect focus. We can then measure the distance of our audience from the screen and, by applying a little trigonometry this distance and our one minute of arc, come up with a physical dimension on the screen for the largest dot the audience will see as a single, sharp point.
- Wheeler, P
This is based on that article floating around that has the picture of the toy trucks called sky something or other?
Well, it works mentally, but its technically wrong. He doesn't say that for his comparison shots he moved backwards, and that this is what caused that 'space distortion' for the given frame of view, not focal length.
Things in the distance appear flatter, and focal length simply magnifies this optically to give us a field of view our eyes could not achieve. Focal length does not distort space! And slap anyone who would tell you so.:nads:
My comment was not based on an article floating around the web. If you change focal length but keep the subject size the same (by moving back and forward) and the f stop stays the same then the DoF will stay the same. DoF is not the same as Bokeh appearance which is greatly affected by magnification.
Wow, the 2/3 sensor looks significantly smaller than Super16 to me, which is what I thought everyone meant when they said "the 2/3 sensor will give you DOF workings almost exactly like 16mm film." Just a guess, but it seems to me the 2/3 sensor is more like a full 3 stops away from Red One sensor when it comes to apparent DOF rather than 2.5 like many have been saying.
