Final Alpha..
Jarred Land
Fire Chief
Staff member
Ok.. here it is guys, the last REDCINE-X alpha before the code guys re-group. Enjoy.
Lots of bug fixes and a few things new:
-Drag select multiple clips from browser/bin
-FPS playback speed indicator
- Delete key removes clips from timeline
- Command-F Fullscreen mode
- Toggle Rocket on and off
And a Buncha other stuff I can't remember right now.
Http://red.cachefly.net/REDCINE-X-A6.zip
Nice! It's fixed a big problem for me - I have this R3D that I downloaded that broke somehow. Before when I tried to play it, it would work until it got to the broken bit, and then all the clips would go black, the histogram would mess up, and I wouldn't be able to play anything without restarting the program. Now it's all fixed - I just get messed up video while playing the broken part, but everything else seems to work.
EDIT: With a little more playing around, it seems that the clip still messes things up - after I play it I can't use curves any more... Do you want a copy of it, Jarred?
One other thing - what does the package install that needs root privileges? Because I just dragged the old alphas I had to my trash, but if it's installing something somewhere else should I have uninstalled them differently?
  • Thread starter
  • Admin
  • #3
it now should automatically remove the old version and then install the new version.. which is why it needs those permissions i would imagine. no need to delete the old version anymore.
You might want to do a permission repair, and as Jarred said it installed strait up, and anything that went on in the BG was done without asking for anything.
Running SL.
didnt remove my old version on install.
  • Thread starter
  • Admin
  • #8
Ah sorry..it only looks for the version beforehand.. and this version is a few builds past what you guys had last.
My newly installed version calls itself REDCINE-X-00001520 and the original is still just REDCINE-X
Wow, nice surprise Jarred, as you said this with the last alpha!
THANKS SO MUCH!!
As an Alpha build keep the build number in the app name... that way the auto installation down the road will go smoothly. You can garbage your old REDCINE-X version.
ha ha ha Harry be gentle on the windows guys they will hiss at you :)
Rocket toggle off/on isn't working for me. Is there a firmware or restart we need to do?
The rocket button is constantly lit yellow.
Hey, speaking of Redcine X...
It crashed on me today when I loaded up a pretty long (8 minutes plus) take and tried to adjust the scale of the timeline.
If I experience a crash, is it useful to save the OS X Crash Report and send it to you guys? I'm not even sure if you can save it... I think it always gets sent directly to Apple. But would that be useful info to your coders? If so, how can I save it? Just copy all the text?
Harry
Hey Kevin.. goto the settings menu and check the USE ROCKET option.. a little popup will say " Redcine-X will not use Rocket on next startup " .. then restart the program.. when it restarts the icon should not be lit.
Harry dont worry about the crash reports for now.. the framework is going to change tremendously over the next couple weeks so the crash reports are of little value.
You guys however can give usability requests... those always help.
