Vegas 9.0b released!
Miltos Pilalitos
52
Athens, Greece
www.pilalitos.com
Notable fixes/changes in Version 9.0b
Resolved an issue that could cause the contents of media generators (most often text generators) to change when the Undo command was used.
Fixed a bug that could cause Vegas to crash during startup on some computers running Windows XP.
Fixed a bug that could cause still images to appear out of focus when rotated via Event Pan/Crop.
Fixed a bug that could cause audio dropouts in XDCAM SD (DVCAM) MXF files.
Fixed a bug that could cause an error when conforming trimmed XDCAM clips on the PDW-U1 deck.
Fixed a bug that prevented some QuickTime files from reading audio properly.
Fixed a bug that prevented metadata from being imported with 720-50p XDCAM clips.
EDIT: It looks as if it's a quick bug fix... The main dish will probably follow soon.
Odd bug?
Odd bug?
Ahoy-hoy,
Using 9B with some short test pieces I found on Scarlet user. They integrate fine (drop 'n' drag) but, occasionally, one of the media bin thumbs turns bright red (255/0/0!) when I double-click to shift it to the trimmer. Drop it to the TL and the same happens to the thumbs there. Once it occurs, the rest soon follow suit and I just get black on the preview window.
Dodgy clip or just a random/known bug?
Ta,
NR.
