RocketCine-X Saving RLX Files
Jesse Korosi
Los Angeles, CA
www.jessekorosi.com
I am not sure if someone has already asked this or not, but I am curious as to whether or not you are saving an RLX somewhere on your machine when you hit the + icon within the Looks section in RocketyCine-X.
If there is such a folder, where is its location? Can you drag RLX files into that folder that you have created in Red Alert? (Example. Your on set creating a look with your D.P, then you want to be able to send that look down the rest of the chain when sending material to the Lab for processing.)
Thanks in advance!
Jesse Korosi
Rocketcine doesn't save the RLX format but it does support the rsx format. Both RSX and RLX will be phased out as soon as we transition to a more future friendly look format.
