Von Thomas
- Jun 9, 2008
- Los Angeles
- www.digitaltechnyc.com
Yesterday I experienced vertical lines in some RED files. It was a long and hot day in the studio, the AC went out in the morning and was not fixed until the early afternoon. Right before lunch was called, the 1st AC noticed lines on the monitor, and we hoped it was just a display issue, but they were on the files. We broke for lunch and I ran black shading, after lunch all was well. Within an hour the lines came back, but in a different place, this time I called RED for an update on the cause. I was told to black shade, I did, and I did again, and to make sure all vents were not being blocked, and that also the ports on the right side of camera (audio, HDMI, USB) were also not blocked as they act as vents to expel heat from the camera. I also applied cold packs and aimed the AC vent right at the camera. All of this helped, but it did not fix the problem. In all I ran black shading 4 times yesterday, after each run, the problem was gone, only to return a short time later.
Is this a heat issue, or a camera defect?
Von
Von
