On 4-perf 35mm film, regular 2x anamorphic lenses will get you about twice the field of view for an equivalent spherical focal length- so a 35mm anamorphic lens would be about as wide as a ~18mm spherical lens. Because the Red one sensor isnt as large (namely tall) as a 4-perf film negative, your going to only get about a difference of 1.5x wider or so (as the Red crops out a section of the center of the image for anamorphic recording), so a 35mm anamorphic will only be about as wide as a 24mm spherical lens in that case. BTW- I havent actually measured it exactly on the Red but I think 1.5x is somewhere in the ballpark.
So... that would make it actually similar to FF35. Yeah? That means, for those of us from a stills background, a 50mm on FF35 is roughly equivalent to 75mm (x1.5) on a sensor like the R1 but, if it's a 2x anamorphic, given the smaller vertical size of the R1 sensor (meaning you're cropping the edges unless you want a 4:1 aspect), that 50mm is back to giving a similar (horizontal) FoV as a 50mm would on FF35(?) Hmmm. Sounds suspiciously easy for me. There's got to be a catch.:confused5:
