Conversion LOMO Anamorphic roundfront F =100/2.8 on Superspeed anamorphic F=100/2.0
St.Petersburg , Russia
Hi !
I am offer conversion anamorphic lens 35BAS25 - 2 , F = 100/2.8 , T = 3.4 on Superspeed anamorphic lens F = 100/2 - on original anamorphic lens will replace optical block on another OKC1-100-1 , F = 100/2.0 , T = 2.3 and lens will more faster ..
Original anamorphic lens 35BAS25 - 2 , F = 100 / 2.8 has optical block OKC2-100-2 . Optical block OKC1-100-1 T=2 more about 10 mm in diameter then optical block OKC2-100-2 which fitted on rear part ( submount ) of original anamorphic lens 35BAS25-2 , therefore it is not possible only replace one optical block to another . Therefore was made new submount ( rear part ) from hard black anodized aluminum ( it more large in diameter then regular anamorphic lens 35BAS25 - 2 ) , new iris ring with new engraving ,on lens was mounted focus cand iris gear rings made from black anodized aluminum ARRI standard 32 pitch , lens has stainless steel PL mount , new anamorphic lens F = 100 /2.0 will has T=2.3 .After lens carefully collimated .
If you want to convert your lens on more faster – price of conversion
$ 1900 .
It is possible you will say that it conversion expensive - I am return for you old block of glass OKC2-100-2 and you can sell it for $ 200 - 300 and save money
And the same conversion it is possible to make from LOMO roundfront anamorphic lenses :
F = 50 /2.0 type 35BAS22 – 1 and F = 75 /2.0 type 35BAS23 – 2 – this type of lenses has absolutely equal front anamorphic part – difference only in rear part with prime lens and with this front anamorphic part it is possible to made else some anamorphic lenses F = 135/2.8 and F = 150 / 2.8 – I have sold some lenses and buyers was very happy .
  • Thread starter
  • Banned
  • #3
Hi !
The price of anamorphic lens after conversion on superspeed lens F = 35/1.5 , F = 50/1.2 , F = 75/1.4 , F = 100/2 - each lens $ 4900 , F = 150 /2.8 - $ 3200
Best regards
Sergey
so these are anamorphics for sale? Or superspeeds converted to anamorphic? I'm confused as to what is being offered.
  • Thread starter
  • Banned
  • #5
I am offer conversion anamorphic lens from F = 100/2.8 to lens F = 100/2.0
Was used front anamorphic part from serial anamorphic lens 35BAS25 - 2 F = 100/2.8 ( see photos below ) or 35BAS22 - 1 F = 50 / 2 or 35BAS23-2 F = 75 / 2 , all front parts from its lenses is absolutely equal . If you want to receive anamorphic lens F = 100 / 2.0 I am need only front anamorphic part from serial LOMO roundfront anamorphic lenses 35BAS22-1 , 35BAS23 - 2 or 35BAS23 - 2 .Technician will make rear part from hard aluminum , will make new iris gear ring with new engraving , black anodized and will put on it block of glass OKC1-100 - 1 with T = 2.3 ( see photos ) + PL mount from stainless steel .. It is possible to made with it front anamorphic part else anamorphic lens F = 150/2.8 .Exept Anamorphic Lens 35BAS27 - 1 F = 35 /2.5 - it has more large diameter of front anamorphic part .
Best regards
Sergey
