RED 640GB - Esata vs FW800
Steve Freebairn
www.freehillproductions.com
Nothing super scientific, just a quick and dirty aja speed test. The esata is through a cheap little esata adapter that is a x1. The fw800 drive test was powered (as recommended) from an external adapter then plugged directly into a nehalem Mac Pro.
And RED isn't joking when they talk about demanding and specific requirements for RED Media, look at how flat those graphs are. That's incredible and consistent.
Update:
Pic 12 is esata
Pic 13 is to show test settings
Pic 14 is esata graph
Pic 15 is fw800
Pic 16 is fw800 graph
Can't see the pics well enough to read the numbers. My guess is that the 640's are 2 500gig drives that have been adjusted to make them appear smaller and therefore faster.
EDIT:
Thanks for the update. Yes that is very even. How much was on the drive or was it empty?
EDIT August 8, 2009:
Jeff, from the speeds I don't know where I got that idea from. If they had short-stroked the drives it would be faster than that.
Where did you come up with that reasoning?
There's 2x320GB HDDs in there. I haven't benchmarked one myself yet, but they should be a good bit faster than the 320GB RED Drives, assuming the internal RAID controller is not a bottleneck. Most 2.5" 320GB 5400rpm HDDs on the market are 45-55% faster in sustained transfers than their 160GB counterparts. So I would expect similar speed relationships to translate over to the new RED Drives. That said, an eSATA connection would be more desirable if available. FW800 has about a 95MB/s max rate, not taking overhead and other inefficiencies into account. FW800 wants to top out at about ~75MB/s on my '08 Mac Pros and G5 Quad systems... My '09 Mac Pro is giving me about 80MB/s. Whereas eSATA can handle over 300MB/s and I can sustain almost 90MB/s from a 320GB RED Drive there. I would be surprised if the new 640GB RED Drives can't deliver 120MB/s or more using a LEMO to eSATA cable.
Jeff have you had any experience with the mini G-Raid?
Not really, I've only used a couple of them when copying footage for others. Can't really comment on them.
Looking at the I/O performance in Steve's tests, I'm really wondering if the onboard RAID controller isn't a bottleneck. Those are about the same numbers I get for a 320GB RED Drive, the FW800 numbers are the same, that's as good as it's going to get under this test. Under eSATA, It seems the write speed is about a bit faster than what I see with this test of the 320GB drives, but the read speed is right at 90MB/s, which is what I see with the 320GB drives as well.
Anyway, I'll benchmark a 640GB Drive soon... Just haven't got around to it yet as I don't personally own one.
I'll test a 320 sometime soon. The card in this computer isn't fantastic, I'll wait until I get time with a high end RAID card for super scientific tests, but I remember looking for something like this awhile ago, and couldn't find it so I just threw some numbers up. Most of the time I end up backing up to slower drives than the RED drives anyway, so once Conrad changes R3D data manager to copy to all sources at the same time/speed, then unless I'm going to 2 or 3 24 Drive RAID 6 setups, then 90MB/sec will be just fine by me.
