post nightmare.. help
Zakaree Sandberg
43
Los Angeles, CA
Did a 20 min project... and now i have 3 days to grade/render it...
if anyone has time.. please help me out via email or PM
edited in final cut..
log and transfer to 422 (not hq)
edited those files...
now need to send to color and grade the r3d's and online the project..
what is the best way (send to color button in final cut?)
also.. anyone have an estimate on how long 20 mins will take to render in color?
im effed
zakaree@cox.net
export an xml conform to your desired frame size & match the old shots with R3d's in clipfinder, import that xml back to fcp>send to color>run color fixer on the color project file>grade sequence>render>send to fcp
20 minutes should be able to render overnight with no problems, it's a lot for color to handle though, i'd split the timeline into 5 minute segments.
When you're strapped for time I find the best workflow to be.. grade proxies in FCP.. send to Color.. grade.. send back to FCP.. resize as necessary. done?
if you've already worked from a log and transferred file,
I would export xml, online in clipfinder, send to fcp, send to color, grade, then back to fcp again.
20 minutes is like 6 hours of render time on a 3.2 octo
