Dan Hudgins
- Feb 16, 2007
- San Francisco, CA USA
- www.dancad3d.com
I made a small utility to test a PCs HD,SSD,CF,SD,USB memory stick, drive's average speed for saving frames.
Please help me get an idea of what speed you computer can operate at by running this utility on your PC computers, it is a simple DOS program, and should run under ME or XP Home, maybe some versions of Vista. Its a 32bit program, so probably won't run under FreeDOS, I could make another version for that maybe later.
Anyway you make a folder (8 letters or less) and give the full path like,
C:\FOLDER\
Unzip HDSCK002.ZIP into it,
rename the file DANHDSCK.BIN to DANHDSCK.EXE, I renamed it to help it get past some virus filters that don't like EXE files.
You enter the values asked for i.e.
C:\FOLDER\
2592
1102
1.5
1440
And let it run, it should make 1440 "frames" in less than a minute, but may take longer, it then gives a report of your HD/drive speed.
To remove the frames you need to use the DOS DELETE command like this,
DELETE C:\FOLDER\00??????.XXX
Or you can use the Windows delete marked block command, but you then need to empty the waste basket also.
Please tell me in a reply or PM/email what frame rate you get on your system from the settings give above. The program works up to 6K, but I am interested in 2592x1102x1.5@24fps for now, to see what people can get on their RAID arrays, SSD, and normal HD.
Its best to enter 14400 frames if you have the free HD space, since the frame rate tends to fall off as the frame numbers go up, 14400 is 10 minutes of recording, so that would be the longest shot for the most part.
Thanks for any help. I need to find out what drive types can record better than 24fps, I only get about 1.5fps on my system, and 4fps on my Brother's, at 1440 frames, so let me know what you get and what type of drive you are using and system specs and number of frames made, it will be a big help, thanks!
EDIT: NEW WGUI-v0.04 now put in ZIP file for testing under VISTA and WIN-7 etc! let me know if it works, rename DANHDSCW.BIN to DANHDSCW.EXE to run it, see about.txt in the ZIP file.
EDIT: APRIL 2010. I removed the ZIP file from here, if you are interested in it you can PM me, I am thinking of making a revised version and it could be too large to fit in the ZIP file space here, so I may post it on my WEB site. Thanks for the results they were very useful and constructive.
C:\FOLDER\
C:\FOLDER\
2592
1102
1.5
1440
