FCP Workflow 2, L&T Onlining Problem
donwaldi
New member
Hi there!
We shot a documentary on RED and edited the whole stuff in FCP using Workflow #2 in the RED FCP Whitepaper (ProRes Proxies, finish with RED QT Media). All Proxies have been rendered using the Log&Transfer Tool in FCP. Now we wanted to online eveything. We did every step which is standing there (reconform, red using prores setting, mediamanage, l&t switched to native). Our problem is, that when we go on "Batch Capture" everything is getting recaptured in ProRes (??) in crazy resolutions.
Does somebody here know a solution? Please Help! ;)
thx!
Christian
Hey,
Make sure that the preferences in the log and transfer window are set to RED ->native. If it's still set to Apple ProRes then that's what you'll be getting. Hope this helps.
Also - if you shot in 16X9, then the dimension should be different from that given in the whitepaper. The whitepaper explains the 2X1 workflow. For 16X9, set the preset to 2048X1152
Cheerz
p.
