Intel Slashes Prices on SSD Drives - Improves Performance
michael zaletel
Phoenix, AZ
http://www.informationweek.com/news/storage/systems/showArticle.jhtml?articleID=218501623
The new X25-M and X18-M can replace current models in systems without modifications. They are also drop-in compatible with similar size hard-disk drives. The X25-M is available in quantities of 1,000 for $225 and $440 for the 80-GB and 160-GB models, respectively. The previous prices, announced in February, were $390 and $765, respectively.
-michael zaletel
(shooter)
Yesss.....
not sure who to trust but i've only seen claims that ocz beats intel on the ever important write speeds...
http://www.custompc.co.uk/news/605377/ocz-claims-apex-ssd-beats-intel-x-25-m-on-write-speeds.html
As I said they do on the "old" intel but the new ones can't say until we know the specs of the read and write of them. All they say is that the latency is improved with 25% - which leads to better read and write, but how much?
As for OCZ - they're 120GB and 250GB for cheaper price though
Do you feel safe with a single OS SSD drive? Do you have two in a RAID-1? If so, do you use MLC's in RAID-1? Or do you still only use SLC's even for RAID-1?
Back-ups aside, if the OS drive gets corrupted you could be down for most of an expensive day, and you could look like a dummy in front of the wrong people. A RAID-1 would let you keep working through.
sorry i missed that detail but here is a general roundup of the 2nd generation ssd speed test done this week:
Pros:
Best in class IOPS performance
Best in class sequential read throughput
Low cost (provided the distributor markup is low enough)
Cons:
Write speed, while a bit higher, remains limited to 80 MB/sec
Minor fragmentation-over-time effects
http://www.pcper.com/article.php?aid=750&type=expert&pid=1
