....and what about keep the camera cold when the temperatures goes high?
I had this problem recently, I had to stop the shooting for 5-10 minutes and put a fan on it because I was worried about the high tmperature reached.
Seconded!I hate to say this, but I'm gonna, if you are shooting RED (and especially if you are new to RED), you should have on set a RED Tech that can assist you with exposure and give you info as to how RED sees. Now before I get ripped, let me qualify that. RED is new, it's process is much different than shooting film or video. Because it is new technology, using past procedures most often will result in not using RED properly, and you having a bad day. If you have been shooting digital still for years, you will get this quickly, but if you've been shooting neg film for years, you will not have the best results using that workflow.
I know the above does not solve your problem, but it something that needed saying, especially for those new to cinematography, and definitely those new to RED.
Use a gray card in the beginning of your shot, make sure it's in the KEY light. Each time you change lighting, shot another gray card. When bringing your clips into RED Alert, click to bring that little square on the gray card, and click the WB tab, your picture will neutralize, and all color cast will be corrected. If you had done this, your blue cast would have been eliminated, and you'd be happier.
This needs to be read again! It is so true! I always tell our clients to judge exposure not by what they see on screen, but by the histogram/false color meter. Sometimes they listen, most times they don't, with the result that they get less than optimal imagery from the camera.I see people trusting the output on an uncalibrated monitor and under or over exposing the image. Because it "looks too dark" or "looks too bright." Just trust the histogram for exposure.
Those of you new to Red's way of shooting - remember you are shooting for a fat dynamic range negative, NOT for the best possible picture on the little LCD from the camera. The histogram is your BEST tool for achieving this. Then in post you will see how much better your image becomes.
