HD Hildebrand
- Dec 28, 2006
- planetearth
- www.hildebrandfilms.com
OK, trying to get my settings straight. I could keep doing tests, watching tutorials and reading every white paper or contradictory posting out there - or I could pose the questions here. Well, time to seek the wisdom of those who've traveled the path.
Here are the AE settings I've deduced so far based on R3D footage shot in RedSpace:
In After Effects -
Turn off "Interpret as Linear light
Project settings - Color settings - depth: 32 bits per channel (float)
Working Space - (Had "None") changed to HDTV (Rec. 709) (not HDTV Rec. 709 16-235)
Is this all correct so far? Should I have HDTV (Rec. 709) 16-235. I believe it should be 0-255 for digital doesn't have 7.5 setup - is that correct?
Also, should I check "match legacy after effects quicktime gamma adjustments"?
Sincerely appreciate any wisdom on this,
Dale
In After Effects -
Dale
