Barry Longfellow
- Jun 22, 2009
Hello everyone!
I wasn't able to find this among my searches in these boards, so hopefully I'm not being redundant and it's a simple solution:
What color settings should be used in RedCine when going back to the R3D files to match transcoded footage from the Log and Transfer process?
We are cutting a long form project that will output to DVD/HD Master. To make things simple, we transcoded all the source footage into Pro Res 422 HQ files with the Log and Transfer window.
This would normally be the end to the story. We'd send to Color, make some nice tweaks, then render out. However, the producer wished to 'change the focal length' of a few shots, which we all know is no huge deal when working with 4K. In fact it's pretty awesome to do so without visually degrading the image in HD space.
So I pulled a test shot into RedCine. But after rescaling the video, and exporting to Pro Res 422 HQ, I noticed a dramatic change in color. The subject's shirt changed from a saturated red to a dull orange.
Why does the transcoded files within FCP's Log and Transfer plug in look so much different than exporting from RedCine? It is clear that the footage is a much cleaner when compared to the temporary scaling we did in the motion tab within FCP (his face is more defined and crisp). However, the color is completely off, which will make matching in Color an added step.
Can someone help me out? Or refer me to a related post?
Are there specific settings that Final Cut uses in the Log and Transfer (in conforming to Pro Res 422 HQ) process that can be used in RedCine to match perfectly?
Any suggestions would be gratefully appreciated! And please let me know if I need to clarify anything..
Thank you! :smiley:
Thank you! :smiley:
