I have the MB-20II with all the clip on stuff too.
It's so heavy it negates a lot of the ease of a clip-on. I'm probably eventually going to buy an LMB-5 or MMB-1 for when weight matters, because the MB-20 doesn't "do" lightweight.
I have exactly the same setup as Mark P, with 3 stages & 138mm, and with the clamp-on adapter attached it's no lightweight....but if you have the 2 stage version it maybe a good option.....?
Its a very solid adapter and i have used it about 3 or 4 times, its just not practical if your trying to go to a real lightweight mode.....
I'm actually going to sell my clamp-on adapter and all of the adapter rings.....if anyone's interested.....
