Joe G.
We talked about this before, but I never heard a response from anyone at the company.
As most here would know, HDR combines 2 frames to make one frame with expanded dynamic range (more highs, more lows) by bracketing the exposure of consecutive images. It occurs to me that this is feasible, since most people shoot 24 fps, and use a 180 degree shutter. If you record at 48fps, there is the possibility of using the two frames and putting them together into one intended for 24 fps playback.
Here's my suggestion:
HDR for 24P out of 2 combined frames:
2 F stops over bright protection
48fps at 360 degrees (1/48s)
48fps at 90 degrees (1/192s)
or
1 stop over bright protection
48fps at 180 degrees (1/96s)
Some piece of software can combine these quickly into 24P, with varying mix settings.
Anyone there done tests?
Other manufacturers will no-doubt step up and give this a try if Red doesn't.
There is also the FUJI idea of using photosites of various sizes across the array. The larger sites gather more light than the smaller ones. Anyone at Red considering this approach to expand dynamic range?
Now, this doesn't have to work great in every shooting situation, as in walking along with dialogue. But, the option would be great for landscapes, or scenic shots.
or
