I Bloom
I'm shooting a film with several night interiors. I'm going to be motivating everything with practicals. Aside from photofloods what is the best way to shift incandescent bulbs to daylight.
IBloom
IBloom
What does HMI stand for and are all HMI's daylight temp?
Havn't used Practicals yet...
What bulbs can I use in standart fixtures and how bright and in what Kelvins can I get them? Do I have to prepare or have special Practicals when using high wattage bulbs? How long do those live? Are they expansive?
I haven't used them yet. True, you could gel a tungsten, but I thought we were talking about light bulbs inside of practicals, which are near impossible to gel, so that leaves blue-painted photofloods... but you were asking for alternatives to that. Were you asking for tungsten alternatives?
Well, I don't trust CRI's yes because of the green content. If they don't get the proper wattage I think they are likely to shift.
Photofloods are too bright and they burn out after two hours. I guess the ideal is a 100W bulb painted CTB.
IBloom
And if you would need to use high wattage bulbs (do you?) would yor gaffer prep the Practicals as well by changing the socket?
In Terms of Chinese Laterns:
Do you use the normal paper ones, wouldn't they have a slight warm colour shift, or are there some with Frost?
Promising:
http://www.filmtools.com/bca250wattge.html
I'll post some stills if I shoot with these. Should I expect the output to be closer to a 60w tungsten?
IBloom
