It's most noticeable while shooting Wide Shot VFX elements on stage when focus is critical. I'm usually using Cooke S4 14 to 21mm or the Zeiss Ultra 16 lenses from 6mm to 12mm.
Focusing on objects in the 15 to 20' range is most difficult. I've even tried to loosen up the back focus to see if I could dial in better focus. It might be a result of shooting in the 100 fps range at 2k with a 180 degree shutter that just doesn't hold up like 4k at normal speeds but I doubt it.
It's most noticeable when shooting background plates at distances more than 15 feet do we see this, and it's on every Red we've tried.
Try looking at the same field of view at 2k with a 4k shot at around a 27mm or wider. Try to match the width of the 4K shot as close as can be gotten with the glass you have available for the 2k shot. Focus on the objects at 15 to 25' range and see if they can be focused on sharply. That's my problem when shooting background plates for VFX shots at off speeds which need to go to 2k to reach desired speeds. I'm finding it impossible to sharp focus on objects at those distances when that wide at 2k.
