Will the Epic 645 hava a OLPF?
Michael Lindsay
London UK
www.16ozfilm.com
I ask this as many in the stills world like the look of false detail (crunchy) and I know of no medium format digital system with a OLPF...
Additional questions:
with 6micron photo sites and stops above f11 is the fuzziness due to diffraction enough?
Am I wrong and is there a MFDS with a OLPF?
Is it possible to make a OLPF big enough for the 645...
Has pulling the OLPF away from the sensor (red 1) allowed it to be thinner?
Personally I hate false detail and hope it does have a OLPF (and slightly assume it will). That said I know this world a bit and am curious how red will deal with the pixel peeping assistants and their 1 to 1 digital loupes?
kind regards
Michael L
If I recall correctly I think the Mamiya ZD & ZDb back had a detachable OLPF. really pushing the memory now but I think the anti-aliasing could be corrected with software? either way, I think you would get that false detail in both, not sure what they do now days.
Tim.
At f/11 the diameter of Airy disk (the smallest point on which a beam of light can be focused) is 17 microns.
Hi Pawel
Do you think that is enough to not need a OLPF?
Tim
Do you mean that the softness from a OLPF can be compensated for with edge enhancement?
Michael
It's more than enough. The smallest detail the lens can focus at f/11 would be 3x3 pixels large. :idea:
I aked not because of the maths you gave but because I've seen lots of medium format stills which seems to have aliasing but are shot at f11+. Maybe I'm wrong and the crunchiness I've seen in the Raw files is the result of something else.
I will dig out some examples and check..
I am excited by the Epic 645 but am wondering about its viability!
regards
Michael
Michael,
Sorry, I'm really not sure, I haven't had much experience at all with the ZD's, i just remember there being a detachable OLPF, and the software did some funky stuff to correct for this (I never went down this path), but I assume that the software would enhance the edges or something similar.
Tim.
Pawel are you sure you are not talking about f11 on a S35 lens? I'm asking because the relative aperture of f11 might be a larger physical aperture size on medium format than on s35 glass.
it wouldn't matter, f number is only affected by the focal length of the lens and the apertures diameter. so any 50mm lens at f11 will ALWAYS have an aperture diameter of 4.5mm.
Tim.
The sensor size is irrelevant.
For most people it would be enough, IMHO.
Yes. It's only money. (Cost rises exponentially with area for the good crystal ones.)
I think MTF is the best way to measure the effect of diffraction. The higher the frequency, the lower the MTF (i.e., smaller pixels have lower MTF at Nyquist due to diffraction).
To avoid aliasing, an MTF of 0% would be the theoretical ideal, but in practical situations I don't think it's necessary to go that low. I think 10% MTF is sufficient to prevent aliasing. Using the formula for MTF of diffraction[*], I calculate that MTF drops to 10% for green light (550nm) at f/11 at 3.7 micron pixels. Using red light (750nm) I get 5 micron pixels. Both of these are slightly smaller than the 6 micron pixels in the EPICs.
Again, it's a question of what MTF you consider aliasing taken care of.
[*] 2/pi*(acos(f)-f.*sqrt(1-f.^2)) where f is 1/(w*f-number).
Thanks Daniel,
I thought the MTF would reach 0% at the size of Airy disk (17 microns) corresponding to f/11. The reason the MTF would reach 0% at this frequency is because the size of Airy disk is the smallest detail the lens can produce. Thus, the frequency limit would be around 17 microns.
Are you sure that at f/11 the MTF would be 10% at frequency of 3.7 microns? Even from practical experience, lenses on most DSLRs (6 micron pixels for argument's sake) start to be diffraction limited passed f/5.6.
Have you considered the fact that the intensity of the Airy disk varies from the center to the edge? Or the effect of alignment on a grid of square pixels for sampling? That to resolve two lines requires a minimum of three samples: one for each line and a third to show a change in intensity (half the Rayleigh criteria spacing)?
I think I got my math right. Here's an online source for the diffraction formula:
http://www.mellesgriot.com/products/optics/os_2_2.htm
Agreed. Most of us have all of our practical experience with diffraction in similar situations: noticing when diffraction starts to affect the image, and trying to avoid it. But "starting" to be diffraction limited is not enough to eliminate aliasing. For example, diffraction can cause contrast to drop from 80% to 40%, but that's still enough to cause aliasing.
Few have practical experience in the area covered by the thread: finding out how small pixels can be before MTF drops below 10%.
As far as I can tell, they're only talking about the typical situation, which is avoiding diffraction:
What is required is a lens system with a fairly low f/# to even theoretically achieve the sensor limited resolution
In this thread we're talking about the extreme opposite end. First diffraction starts. Then it gets annoying. Then it gets bad. Then it gets really bad. Then it finally drops all the way down 10% MTF. Only then is aliasing finally taken care of.
They are talking about trying to be "sensor limited", which means avoiding the "start" of diffraction, or at least avoiding the "annoying" phase of diffraction, but certainly not going anywhere near 10% MTF. HTH.
Tim.
I stand corrected. Very educating posts BTW :thumbsup:
[I said:
What is required is a lens system with a fairly low f/# to even theoretically achieve the sensor limited resolution[/I]
Great information, thats going to give me something to chew on for a while, thanks. :thumbup:
Tim.
structure
structure
The circle of confusion is not just a fuzzy blob with a bell curve, depending on the lens formula it can have some structure, and different structure at different wave lengths, more so off center because of comma.
Also aliasing is not the only issue, you also need to reduce chroma moire.
A good OLPF will cut divide the light over four pixels and help kill those issues, more than just stopping the lens down because the sharpening used in the de-mosaic can be over 400%, which counteracts some of the diffraction making the center of the bell curve brighter than it would be at 100% sharpen (i.e. no sharpen). Also the sharpen needed brings out other shapes in the circle of confusion, which is not a circle off center but looks at bit like a bird on some lenses with the comma as its tale.
I've been stopping the lens down in our scanner to reduce the grain in film scans, but when you sharpen most of the smaller details come back, so it is not an on or off solution. Also you get smaller details in the UV, so if you try it you might want to use a UV+Violet cut filter.
