Looking for LEMO part numbers...?
C.H.Haskell
www.haskellfilms.com
Trying to locate part numbers for the LEMO cables that are used for RED LCD and REDRAID drives. I am missing the little screw on back caps and generally need to have replacement parts...anyone know what series these cables are so I can call up Lemo and find out what I am looking for?
Link is still working :
EVF/LCD information from PDF .
Cable End - Part Number: FHG.1B.316.CLAD62Z male elbow, FGG.1B.316.CLAD62Z male straight
(PHG.1B.316.CLLD62 female)
Shell Style/Model FH*: Elbow plug, cable collet
Key G: 1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Size 1
Series B: Metal (Mechanical Keying)
Insert Configuration 316: 16 Low Voltage
Housing C: Brass (chrome plated)
Insulator L: PEEK
Contact Type A: Male solder
Cable Fixing D62: 5.1 - 6 mm (0.2 - 0.24")
Variant Z: Nut for fitting a bend relief
