JonathanF
Thanks for posting the new builds of RedAlert with the new Color Science updates. It's made for an interesting day.
I took a handful of shots from a film we're working on right now and the results are pretty dramatic. It's hard to see without looking at the rec709 grading monitor or a projector calibrated to rec709, but the difference is pretty big.
These images are from RedAlert v3.60 and RedAlert 20.0.1b, both using identical settings to output images in rec709. The last two images are stripes showing a comparison between the two and one with just the blue channel. The blue channel is certainly less splotchy in the 20.0.1 files, but the color shift is pretty extreme. Any comments?
The new build seems to have much more blue in it or be generally cooler than the older 3.6. Is this what you guys are seeing on your side as well? I haven't labled the images as the warmer ones are obviously the 20.0.1 files.
What's the general thinking on working with build 17 or 18 footage and grading using build 20 SDK apps (when we can build them)? Were you expecting this much of a warm shift in the color?
Thanks again,
:J
Thanks again,
:J
