HOw far can the brain be away fm the recorder
tj williams
www.camera-person.com
There are several applications I'm interested in where separating the Epic Brain from the breakout and recorder part of the camer will be advantageous! Any word on wheather there will be a cable and how long it could be???
I echo this question! I've got the same requirement.
Will this cable be a chunky, not-to-flexible multicore, a coax or maybe fibre optic(plus power)?
JohnF
How far can the brain be away from the recorder?
Are you looking for just recording to be extended and for how far?
It would be awesome if there was a way to separate the brain/lens from the friggin' RAID 0 server it's gonna take to record RC250 9K.
The major reduction in weight would equal a major reduction in money spent on things like jibs.
Though I do realize that you can only maintain that kind of bandwidth for a limited distance and the cables would not be cheap.
At the moment I'm looking for 2-3metres from the recorder. Though it'll often be under 1metre.
JohnF
would be great if the cable would be long enough to hide the stuff in a bag,
only the lens and brain in the hand.
would be awesome to get some cool shots in exorbitant expensive places hehe
I'd echo this request. The brain-to-cable-to-recording module in backpack approach worked wonders with the SI cameras used on Slumdog Millionaire, jumping over walls and running through the crowded slum streets.
We are configuring our Red so the batteries and Red-Drive are in a padded backpack for hand-held and Steadicam, but it would be wonderous to get the hand-held weight down even more by having more of the 'body' in the backpack as well - an opportunity for the increasingly modular Epic and Scarlet systems.
Perhaps even a 'Red' gyro to attach to the bottom of the brain? Smooth dolly shots are all well and good, but sometimes you can't beat leaving the sticks behind for a rapid, action-packed shoot. The world is your oyster.
It would be perfect for setups like this Slumdog Millionaire handheld setup with everything but the brain hidden in the backpack of the operator:
Also it would be absolutely great for car-shots. You could go handheld in the car or mount it at any place at creative angles and mount the rest of the cam elsewhere.
So about 6 feet would be an immense help for different uses.
Jim once indicated it would be around six feet...
Because of the complexity of the transfer, it was unable to be longer.
I really hope a tether/extender/module-attacher-gizmo is still in the works. This would help me out tremendously.
Peace,
-Harry
Hi Leif,
you probably know that this is the original Oscar winning camera?!
I've shot with it and can say that a SI2K Mini is too light for handheld - unwanted high-frequency shaking is happening all the time.
You notice the "bomb" attached to camera. It's a gyro that adds weight. I switched it off, the weight alone helps a lot.
Otherwise SiliconImagine's concept of brain-cable- recorder is great if you would have the oppertunity to use it as a single unit as well, which you cannot unfortunately - but Epic will of course. SI utilises a simple ethernet cable.
BTW: The camera makes very nice pictures, very different to what the RedOne does at 2K.
The cable should be at least 45 feet, better 100 for use on a crane.
Hans
Hans
The SI camera has always been available in a self contained, single case configuration - with the front end (the piece that holds the imager, the same piece that constitutes the head for the Mini) being removable. The Mini is a separate product that lets you supply the back end via a computer or a laptop.
Hi Leif,
Yes I know for sure. Heard a lot of stories from a friend at Pille Wiesbaden.
I was gaffer on the first european feature film shot on the SI2k in Albania 2 years ago (a german, albanian, kosovarian co-production). Even the first production shot on 25fps. The cam was (and is) owned by the kosovarian production company and was sold by P+S Munich. There was an article in the 10/07 issue of the german "Kameramann" magazin about our experiences with that film. I understand that a lot of issues that we adressed are better now or even solved, so that article isn't up to date anymore.
The film was shot 90% handheld and we had an shoulder rig rather than a handheld rig - that helped a lot for keeping the small body steady. That big Anton Bauer battery was perfect for balancing that rig:
Not really "always". 2 years ago there was the "brain" only. The body came about 9 month later.
BTW:
Pille wasn't very satisfied with the Silicon Image body so they designed their own, 0dB silent one. I really love the idea of an open camera system that everybody can "hack" for their own convenience.
http://www.pillefilm.de/Products/details/7533/de
Correct. What I should have said is that it has been available with the enclosure for some time now. Thanks for the correction.
Any official word on the brain recorder distance?
JohnF
