Chris Pickle
Here you seem to indicate that there is really no difference between plugging straight into the camera versus using a sound mixer (human) and sound mixer (device) and as a matter of convenience, it is better to just go straight in. I take exception to this analysis. What it leaves out, are all the duties of a sound mixer that are critical to getting quality audio. Things such as... ensuring proper gain staging, pre fader / post fader levels, detecting phase anomalies from a lav and boom mic, for example, adjusting boom or boom op and other monitoring duties... something that the AC or whoever is listening to camera audio is going to be too busy to do. Most camera people I know would prefer to not even really listen to audio and just leave it up to sound dept.
Yes it can be, but it can also be easy. In my opinion, those who have problems in post are either inexperienced, have not put proper attention into timecode or even basic cinema sound synch details, or continue to butt their heads against the same basic workflow issues without addressing them. Being inexperienced is not bad, everyone is at some point, and I'm not implying that you are. But if we assume that professional tools that are designed for professional results require some professional expertise and competence to operate - there should be some leniency allowed for the process. What makes synching sound on RED more difficult that any other film camera? In fact, RED has TC input / output, film cameras do not. RED operates at the same speed, no matter what the AC mains speed is. No longer do you have to deal with AC pilot tone resolvers and adjusting motors for both camera and audio reel to reel recorders. Not everyone can afford a timecode workflow. If you can, there are thousands of ways you can mess something up, but a very little bit of research and education on TC goes a long long ways and if everyone in the workflow understands their responsibilities, it really can't get much more automated and easy to work with. You going to make mistakes, sometimes big ones, the first couple of times you work with timecode. I know I did. Just make sure those mistakes are made on non-critical test runs and not real deal productions. For those that are on a budget and can't afford decent lights, let along $2k smart slates and $2k to $14k audio recorders with calibrated master clocks, just use proper discipline with a dry erase marker, old fashioned slate, an audio mixer with slate mic, tone generator, and the people willing to adhere to proper methodology. Your DIT can slate the scene with proper notations on the slate, your editor will see the scene and take information on his screen. The mixer can enable the slate mic while the scene info is being called out and now your editor can hear the scene information at the beginning of the audio file. Mixers such as the Sound Devices 302 can precede the slate mic with a test tone generator pulse. This pulse shows up as a nice square constant level spike on the audio file's WAV pattern display. It is unmistakeable and allows one to easily get the audio recorder's file and the camera's scratch track audio to line up... you just zoom in and make the squares line up. The actual slate's clap will be an even more distinct marker that can allow even more exact alignment, its just that the tone's signature will be more visible in the timeline. I'll mention this one last thing, because it is probably the root of many people's issues. In the US, When most of us talk about 24p, we are really talking about 23.976 and when talking about 30p, we really mean 29.97. I see a lot of indy filmmakers who know they want to shoot 24p, actually set their cameras to 24p rather than 23.976. The only people who should really use 24p are those that intend to do a filmout and even that is debatable, as the content will almost certainly be destined for DVD, Blu-Ray, or broadcast release too. When someone runs true 24p frame rates, as an audio recorder, we have to pull up our master clock's speed so instead of recording 48 KHz, our clocks actually have to run at 48.048 KHz. You also have to correctly set all drop frames / non drop settings on all cameras, recorders, and pull up / pull down in the post workflow when the editor ingests the content into a workstation. A lot of people choose the 24p / 30p setting, because it sounds simpler, but in reality, most people should really be choosing 23.976 / 29.97 just to keep things in synch with regular NTSC standards and timings.
I know that there are lots of major projects that ADR absolutely everything. I also know that there major projects, even feature films, that have ADRd only mistakes or in the more rare case, nothing at all. Sometimes they will take the audio mixer's 2-track mixdown and use that untouched. This is of course becoming more rare and the duties of the sound mixer are changing towards more ISO'd tracks and less actual mixing. If you want me to get useable audio next to a highway, there is probably something I can do to make that happen, although it is going to take time and specialized tools.
I absolutely agree. One is simply not able to realize 24 bit resolution in even a studio environment. A typical audio system won't be able to take advantage of around 16 to 18 bits worth of audio fidelity. Really high end systems might get up to 20 bits. Most modern equipment is automatically 24 bit capable, so might as well take advantage of the off the shelf converters that use this word length, but at the end of the day it is the analog circuits in front of and behind the digital chips that really determine sound quality.
If you mean by recording audio line level via a sound mixer, I concur, without the basics, you would be blowing your budget on external recorders, unless you hire a mixer who rocks one anyways. If you mean by plugging the mics directly into the camera, I would have reservations. If there is anyway that you can do it another way, I would highly suggest that you do so. It's not only because of the fact that the RED has substandard mic preamps, which I believe it does, but also the fact that recording audio should not be a set and forget activity, that someone should really be adjusting gain levels for each situation, if not continuously as necessary.
I wasn't suggesting not using a recordist to monitor levels, get good sound, etc. I just meant that instead of sending that sound to a second system, send it to the camera. A great sound person is still very vital.
Syncing in post is a nightmare if you didn't use some sort of time code approach and then use some sort of automated tools. The issue is marrying the audio to the video. In film, the transfer house would match it to your dallies and the audio would be part of the video at ingestion. that's no longer the case with Red. It's actually a massive step backward. You take your video files and then manually sync the audio to the video, then some how get the audio to always be matched to the video when ingested to FCP. A friend wrote us a widget to match files, and to wrap them together, but we first had to trim the audio to the frame with the video and name the audio clips to match it's video. Big big headache. Then, technically you'd have to render out the file to a self contained. We didn't do this, and instead just had them reference in the QT wrapper. This however, gave us headaches in FCP as the app had to look at the video then find the matching audio that was linked in the QT wrapper. Yes some better TC tools would help, but so would recording directly into the camera.
Clearly the sound capabilities on the Red sucks big time. It's a joke really.... not to sound too hard on Red. The idea that you could argue that film has always used a second system so we shouldn't complain about Red's shortcomings is offensive. My old DVX handled sound better. Why not strive for better then how film handled sound, not the same, or even worse then a DV camera.
There are lots of uses for the Red other than big budget films that have massive sound departments. It appears that the Scarlet and other new Red offerings will have a better sound monitoring plan, so it looks like they knew this needed to be better. At least they listne to us.
But as mentioned, on important projects, regardless of where the sound is being recorded to, you will alwyans need a great location sound person.
Chris
