RRafael
i can monitoring Scratch in Apple Cinema 30p monitor with HDLINK PRO HDSL out?
Do you mean a 30" Cinema Display?
You could probably use the HDLink Pro to convert HD-SDI to DVI and connect to a Cinema Display. The 30" will probably scale the 1920x1080 to full screen which means you're not monitoring pixel for pixel.
All in all not an ideal solution. And far from color accurate.
