jake blackstone
- Nov 18, 2007
- Los Angeles
- jake-blackstone.com
Yes, it was a typo, obviously I meant to say PD985...
I'm just curious as to what other options, that are "simpler and more accurate", that can be employed in terms of color space and gamma management in Scratch vs. any other basic transcoding solutions, such as RR, RC, RA etc...That is not correct. What they recommend is PDLog985 with a 2 stop pull. The problem with PD685 is that the available levels are not used optimally as all values are forced to be between 95 and 685, even if those levels should actually be "super black" or "super white." By using PD985, the values are spread more over the available range, as they should be.
Redlog is another option, and a good one if you know how to handle it properly. Of course, if you happen to be using Scratch, there are other options that are even simpler and more accurate. And none of these choices make any sense unless you a) understand what you're dealing with, and b) have a proper film print preview LUT in place in the first place. If you don't, Andrew's advice makes a lot more sense than trying to guess as to what it's going to ultimately look like.
How about one setting for "Lin" and one setting for "Log" that work directly from the RAW data, automatically remove the camera metadata, and only require a user supplied gamma setting? And are globally applied?
(Obviously, I'm not necessarily talking about dailies here, I'm talking more about finishing..)
Andrew, Duart, LaserPasific, Efilms, Technicolor and others are a point of reference for all of us out there, outside of Hollywood... so when we hear a suggestion we put a lot weight on that opinion... we start testing it, same of us we depend whole projects on them... a more in depth with the pros and cons would be better, people want always the best for the less money possible... its a give and take process... Log is much better but not at indie budged, indies they need to know that.
Karilla, please explain your experience so far with REC709 workflows, with two different post houses that using few of the best REC709 monitor available... in comparison to what we do together in log... without even know me in person, just a voice over the phone, the first movie is in Cannes with just the zero print and NO further corrections and now its the second feature that we do together...
The quote from the producer of the first film that we did with Ido:
"Dear Evangelos,
Many many thanks for a job extremely well done and for the wonderful hospitality by you and your charming brother.
Looking forward to working with you again in the near future.
Next time I will not come in Athens, I didn't believe it, now I know, I don't need a corrected copy, zero copy is immediately perfect.
I will be screening the print to a bunch of the top Israeli film producers and I will gladly recommend working with you.
Best,
Haim"
So to wrap up...
- REDLog or PD985 with -1 to -2 in exposure is the best source to start with.
- Until now, Redcine delivers better debayer than Color.
- Log workflow has a film response, that means, it doesn't clip highlights nor blacks, it just compress them. REC709 or linear is just clipping...
- If there is absolute NO chance a project to reach film, then REC709 is possible...
- Even if you are NOT going to film, grading with a Film print LUT in Log always deliver, more Cinematic images, that then, with a LOG to REC709 conversion LUT can deliver the best results for DCI, DVD, Broadcast and BlueRay
- The linear workflow VS Log workflow, for Filmout there is no contest... Log is much better in many ways, RED could be linear, but film is LOG and if you want to play in the film playground you have to play by the rules... film rules... film understands only Log...
- You can do a REC709 workflow, but don't expect THE BEST results...
- If you want a Video look, DON'T do a Log workflow...
- Log workflow for filmout needs a proper color managed LUT driven workflow and that is a fact.-
And as Mikes points out "And none of these choices make any sense unless you understand what you're dealing with"
And that is why I always finish my grade in Lustre or Baselight![]()
Just to expand a little on the modern color management. In the old days of film mastering to DVD we had to do multiple passes for Pan and scan 4:3 PAL, 4:3 NTSC, 16:9 PAL, 16:9 NTSC etc. Additionally, Rank Cintel would drift so much, that we would have to do the global grade touch up, just before the laydown to tape. Luckily, everything then was either SMPTE 601 or later REC 709, easy... Fast forward to today. One LOG 2K DI for everything. DCI, filmout, HD, NTSC and PAL. Just use the proper LUT for all of the conversions. Not so easy, but much cheaper and faster...![]()
Well, in reading this it seems you've been doing this for some time, so if I implied otherwise in my previous post, I apologize. You never know what level of experience anyone on the Internet has these days. Some of the points I was trying to make still stand, though...
BTW, I go back to days long before mastering for DVD. I was around when we were mastering for VHS, Videodiscs, and RCA SelectaVision discs. And the common mastering formats were not digital, they were 2 inch IVC9000, 1 inch C, or 1 inch B formats. So in that context, you had it easy![]()
I have tried using Scratch on several different occasions for grading and I just couldn't bring myself up to wade through totally incomprehensible user's guide.
Shape tracker, multipoint tracker, cloud tracker, again the same source- Flame.
And now, the most important tool for the colorist - Group Grading. Nope...
Can I hide the unused shots in the group I'm grading, so I could see the flow of my shots, like I can do in Luster? Nope again. I can group my shots into groups and all of a sudden, instead of 300 grades, I'm doing 30!
Now, let's talk about being able to apply 12 layers of primary grades, HSL and RGB curves, keys with garbage masks and just simple geometries on top (while tracking), bunch of effects, grain reduction, sharpening etc? Can you see it all playing back in real time? The answer is yes for Lustre and no for Scratch.
As far as me having it easy, the first post house I'd worked, in Dallas, we'd used two 2" Ampex VTR-1200 (not sure about the name) for editing (yes, we did use the razor and the developing solution for edits occasionally as well) with another RCA TR-600 thrown in for good measure for back up. For color camera we had used couple of Norelco PC70? I can't remember that name either, I guess I'm really dating myself![]()
Now, let's talk about being able to apply 12 layers of primary grades, HSL and RGB curves, keys with garbage masks and just simple geometries on top (while tracking), bunch of effects, grain reduction, sharpening etc? Can you see it all playing back in real time? The answer is yes for Lustre and no for Scratch. And I'm just getting startedAnyway, you get my point.
Yes, I agree that we got quite a bit off topic. May be we should start one for colorists?This thread went little bit offtopic,
but just to add some facts.
As Lustre owner I must ask You :
WHAT RESOLUTION HAVE YOU BEEN WORKING WITH ?
1k ? SD ?
Just put a grain/blur/gold/.../, or a key/geomettry with blur on anything
like 2k or above and there is absolutely no REAL TIME.
Even on latest machine (xw8600/fx5600).
12 secondaries RT of high res grading?
Not even in a dream.
"Sharpening" ?
You must have been thinking of something else ?
No sharpening yet.
Head to head on almost the same machine,
Scratch performs bit faster when using 10bit DPX files,
using similar set of primary and secondary tools.
Most Lustre facilities grade in 1k proxy to achive heavy realtime grading.
Regards
I agree with you about the questionable documentation. But documentation in itself does not impact the abilities of the product. If that were the case, Sony would have been out of the professional end of the business years ago
While this is all true, these all fall under the category of "convenience features." Do they allow you to do more in less time? Yes. Personally, I don't use keyers very much in grading because they inevitably create either noise or edge problems - I tend to use either tracked shapes, curves, or vectors. However, I know that a lot of colorists do use them, so, yes, a better and simpler keyer is an advantage.
Well, maybe for you. It's never been particularly important for me. However.... You actually can do this in Scratch, by creating a custom Tray with the shots you want to group. Any trim you do on any one of them can be applied instantly to all of them. Same function, different implementation. And, yes, not as convenient or obvious as on Lustre, but available nonetheless.
True. Also true - this is another convenience feature, not something that provides more precise color correction.
Maybe on YOUR Lustre. I can show you a number of Lustre systems that it would not be true, at least not without a number of background rendering nodes.
I am certainly not arguing that Lustre (or Baselight, or Resolve) is not an excellent product. It is. But everything comes at a price. The notion that it can do some magical things that a "simpler" system like Scratch cannot is somewhat inaccurate if the criteria is the final product and not necessarily how quickly one created it. And although Autodesk will ultimately support R3d files directly, that support is not really there in a particularly complete form today (it actually is in the higher end versions of Baselight and Resolve - but once again, at a much higher price point).
Good lord, you're as much of an old fart as I am :crying: - and I will admit to doing spot dubs on 1200C's at one time..
Do we know each other?
Color grading traditionally always been the most expensive part of the post process. As a result, clients are very sensitive to the speed of execution. If I can finish the job in a third of the time with the same level of quality, where do you think clients will want to do it? Heck, you can successfully grade in FCP, but would you?
My point is, options are there and very easy to use and set up, unlike Scratch, which doesn't even offer any.
Baselight has an even slicker way of real time playback. Just play it back it once and it is rendered in cache, but it has no background render, like Lustre.
Yes, it does. Push one button and it will render the current shot. Or select a range and it will render the range. It will then use those rendered frames for in place playback unless you change something.
Scratch can do exactly the same thing. It is a menu selection.
Rec 709 is a color space, LOG is a gamma description. They are not the same.I have recently done a side by side print test of the same shots graded :
1. Linear on a calibrated rec. 709 monitor, those shots where transformed to log by the custom LUT of the Arrilaser by an independent lab that suggested this workflow. A workflow they practice on daily basis.
2. As log DPX's on my grading monitor with a LUT I got from Evangelos Achillopoulos and printed by his facility in Greece.
The tests were projected to 3 productions that where considering the Redone for a feature film and where debating witch process to follow for their film prints.
Although I was convinced that the LOG way will result in better image I was astonished by the incomparable prints. Black levels, clipped details in the whites, color spread, etc..
At the time of the projection there where two leading DP's and 3 experienced producers that unanimously decided to take the log way although the extra costs involved.
Come to think of it, you could do your own LIN to LOG conversion for the grading and then deliver LOG files for the filmout, so you wouldn't have to pay to the lab to do the LIN to LOG conversion. I think it it's actually cheaper this way...
