Warning!! if your working with r3d files over a network...
Obin Olson
www.dv3productions.com
must do this if you want any playback in vista and cs4 pulling r3d files from a dataserver over gigabit...
Windows Vista network performance can be improved.To improve Windows Vista network performance, configure NetworkThrottlingIndex registry to control the throttling rate.This will apply only when you play multimedia programs.
Multimedia programs and windows vista throttling mechanism:
Multimedia programs consumes more system resources.Moreover multimedia programs require prioritized access to CPU resources as they are time sensitive.In Windows vista, the networking stack implements a throttling mechanism, that will come into effect when you are running time sensitive multimedia programs, to restrict the processing of non-multimedia network traffic to 10 packets per millisecond. This throttling mechanism was designed in windows vista to ensure that the CPU has enough free cycles to play the media without skipping.
However the performance decrease in non-multimedia network traffic will occur only on high speed networks that are saturated to maximum capacity and also only during the active multimedia playback period.
Control the windows vista throttling rate by changing NetworkThrottlingIndexValue:
You can control the throttling rate to improve Windows Vista network performance. But do it careful and with caution as it may affect the multimedia playback quality.
In windows vista registry, change the value of the NetworkThrottlingIndex key entry under the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Multimedia\SystemProfile\
Value type : DWORD
Value data : From integer 1 through integer 70 (Decimal) (Decimal)
You can set NetworkThrottlingIndexValue between 1 and 70. If you want to disable set the hexadecimal value to FFFFFFFF. By default, the value for the NetworkThrottlingIndex registry entry is set to 10.Note that when the NetworkThrottlingIndex registry entry does not exist, the behavior resembles the default behavior.
Thank you Obin.
Your Adobe posts have been much appreciated(Adobe UPDATE please:thumbsup:).
Can you please expand on the effect this should have and any adverse effects.
Were is your computer set to? (between 1-70)
