IAN SUN
- Dec 28, 2006
- Canada, Jamaica
- anansi-mi.com
That is great news Jim. Will the 18mm follow the 35 and 25 and top out at 5.5?
Great news, Jim. The S35-format 300, 100, 85, & 50 mounted on FF35 should have field of view equivalent to ~ 230, 75, 65, 40 FF35-format lenses, right?
I guess not. A 300mm is a 300mm anywhere you use it, so is a 50mm a 50mm whatever camera you put it on, if I understand correctly. You just see a wider angle of view on a FF35 6K than on a S35 Epic 5K. Others please chime in.Great news, Jim. The S35-format 300, 100, 85, & 50 mounted on FF35 should have field of view equivalent to ~ 230, 75, 65, 40 FF35-format lenses, right?
After finally getting a new lens projector and reticle that shows full frame 35mm, I am happy to report the the RPP 300mm, 100mm, 85mm and 50mm lenses cover 6K 2:1 on the FF35 with great resolution out to the edges. The 35mm and 25mm will cover about 5.5K on the FF35 sensor.
A little piece of good news for those that took a leap of faith on a set of RPPs.
Jim
I feel that this discussion is in the same ballpark as saying sensor size has an impact on DOF (and you aren't going to be able to please everyone on the issue). While technically it's the focal distance and lens aperture that effects the DOF, in order to maintain a specific field of view on cameras with different sensor sizes, the focal distance has to change. Therefore, even though there's no literal connection between sensor size and DOF, there's a hugely practical one and it's much easier to think in those terms.I guess not. A 300mm is a 300mm anywhere you use it, so is a 50mm a 50mm whatever camera you put it on, if I understand correctly. You just see a wider angle of view on a FF35 6K than on a S35 Epic 5K. Others please chime in.
So all we need now is a 5.5K setting on the FF35 Epics.
And we need the FF35 brain to not be $33k for the brain alone.
In what aspect ratio? "5.5K" is just a number of pixels...So all we need now is a 5.5K setting on the FF35 Epics.
