Stepan Kment
- Apr 26, 2009
- Prague, Czech Rep.
- pro.bistudio.com
[perhaps David Newman, would You help, please?]
Just downloaded trial of Neo4K and run into trouble. Not with Neo's performance, that's totally amazing and on our Core i7 it even transcodes r3d to cf avi reasonably fast. The problem is .. color management.
R2CF appears to convert r3d's to Cineform encoded AVI perfectly with ton of great options. I am missing color profile setting, though. And even can't tell, what resulting CF AVI is. And faq on CF web site has no information on this.
It seems AFX importer of R3Ds outputs HDTV Rec. 709 profile (can't be changed in any way, probably clips a bit as RED came with their REDspace). What CF AVI is however? Linear? Maybe - direct convert of CMOS response. Or log? Which? What does RED SDK return and how it is set in r2cf..
[Observation: 12 bits in CF 4:4:4 encoding mode should be just fine if r3d to linear 4:4:4 takes place - 12 bits is mysterium's A/D precision I believe. However, any log conversion means information losses in this case.]
Also, for seamless AFX integration, one would certainly need a ICC profile for these CF files. Expect some unknown luminance response curve and white at ??5000K??, which is said to be native Mysterium color temp. or anything that RED SDK renders out.
Anyone could help create this profile? ICC file is.. binary :crying: I bet everyone using CF AVI in AFX needs this - or always applies the same set of filters to each imported file to change the appearance manually, which is -well.. :yikes:
Much the same applies to CF2DPX utility. Seems to me there is no way to change anything there. It'd really help to allow for profile conversion there, eg. from .. linear CF to typical DPX, which is gamma 1.7 and PDlog 685 or 985 interval of RGB values.
[at least, there is a ICC profile for 5500K DCI and Kodak stock present in AFX, so one can directly export and let AFX do the conversion itself.]
CF's soon to be released metadata editor maybe will solve most of the pain with both import and export, we'll simply set proper metadata on converted AVIs and that'd be it. However, that'd solve a problem with a need of specific import ICC profile; still we need to know what profile r2cf exports.
