In the need of lenses?
Felix K.
Germany
I'm an amateur reading here with great interest and curiosity. Now that the new prime lenses are out (with the first people ordering eagerly - nice!) you can still read, that they would like to have an additional 18mm oder even 14mm lens.
Question to all you professional CPs:
Is that because they/you think:
- "without it, I will have to make compromises
[because
a) I can't get the framing like I want it to be or
b) I will have use a slower lens (resulting in critical low light situations)],
or because you think:
- "MY PRECIOUS!!!" :yikes: :)
Explain to an amateur :) pretty please!
Most DP's consider an 18mm to be wide end of a prime lens set. I've gone out on 100's of shoots with an 18mm as my widest lens and survived. On most shoots I would feel like I did not have enough wide options if a 25mm was the widest I carried.
As far as having an 85mm but not a 100mm you can usually move in closer ( or zoom a little in post ) ! If you need to go wider and don't have it you are screwed, you have to cut a hole in the wall or floor, and people get mad if you do it.
Matt Uhry
www.mattuhry.com
@Matt: Thanks for the information and the great photograph! Man, whoever had to clean up afterwards, I don't envy him :D
I find myself shooting many scenes with 3 lenses: wide, medium, tight. Usually 18 32 50 or 25 40 100 or 14 25 40 lend themselves to the scene and shooting environment.
Other times, entire projects beg to be shot with a single lens, like a 25, 27 or 32
