scott william
- Mar 27, 2009
This is my first post so here goes.
Now I know it’s only speculation at this stage but do you think a working S35 DSMC Scarlet will be cheaper then a working Red One kit? Not talking lenses here but i/O module, recording module, base plate…
I plan to go with red lenses which are all PL mount correct? I’ve noticed there are 2/3 format lenses and S35 format lenses. What is the difference between the two and will a S35 format lens work on a 2/3 brain? And will a 2/3 mini prime work on a S35 brain at 4/5K resolution or will it only use part of the sensor up to 3k.
I realize things will probably change, except for the mini primes that is but I’m trying to figure out the most future proof and commercially viable way of going red.
Any thoughts?
Any thoughts?
